Flame Throwers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2003, 08:52 PM
robman909090's Avatar
PONTIAC - Fuel for the Soul
Cool Flame Throwers
Does anyone remember the Trucks TV when stacey put flame throwers on a truck? I didn't think that he used a kit or anything, but would like to know how he had it set up. If anyone remembers, please reply.
Old 11-05-2003, 09:00 PM
Silnod's Avatar
The only way i know how to do it is to have a propain canaster mounted in your car, have it feed into your exhaust pipe right neer the end of the tip, then whenver you want some blue flames just open the valve a little so you release some gas in there it should ignite with how hot the exhaust gets, but dont take my word lol, youll probably blow up and die . The other way is if you have a built car is to putt a really mean cam in it so that it doesnt close the exhaust valve faster enough and just throws raw fueld threw the engine letting it ignite before it get out of the pipe lol.
Old 11-05-2003, 09:04 PM
I know of the propain way, but I don't think he used it on the show. I wish I had recorded it. He only had to push a little switch he mounted under his dash and he would get some cool looking flames!
Old 11-05-2003, 09:19 PM
low77ride's Avatar
http://www.gotflames.net/
This should help you.
Old 11-05-2003, 09:23 PM
New Member
flame thrower
The kit he used was from auto loc. I think the web site is www.autoloc.com there was no propain involved in the system.
2 sparkplugs and 2 coils were mounted at the end of the tail pipe and when he hit the switch it cut the ignition from the engine and puts it to the plugs in the tail pipe. so you have a dead engine running raw gas through it through the pipes and the plugs light it on the way out. doesn't seem to be very good on an engine.
Old 11-05-2003, 09:26 PM
Re: flame thrower
No, that wouldn't be good. I didn't realize that he did that. Sure looks cool though...
Old 11-05-2003, 10:06 PM
low77ride's Avatar
The way i posted above dosn't work that way and won't harm ur engine.
Old 11-05-2003, 10:16 PM
I looked at that site, but I'm not sure exactly how they work. Does it just spark the remaining gas in your regular exhaust? I don't really want a seperate fuel system for mega flames, just short little ones.
Old 11-06-2003, 11:59 AM
gpeak's Avatar
You can go to Truckstv.com
Old 11-09-2003, 08:46 AM
Last journal entry: Rear End Disassembly
is there any way that the flame or spark can lead back into your engine and blow up?
and do you actually have to cut your engine off when you do this, or is it a separate system?
Old 11-09-2003, 10:02 AM
low77ride's Avatar
No i don't think it can go back up into ur engine because the exhaust pressure from the motor is allready pusing out. And ur engine allready is shooting a bit of flame out the engine i think someone correct me if im wrong.The system of the page i posted is a seperate system u have to mount spark plugs in ur exhaust pipe and rout gas to the pipe also its not leftover gas being burt.
Im thinking about buys the instructions to do it myself we'll see. peace
Old 11-09-2003, 01:07 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
This question has been asked before.
Check in the Knowledge Base or search this site at the lower right.
Here's the site with the other's.
http://hotrodders.com/search.php?s=&...by=&sortorder=
Luv the smell of NITRO in the morning.
Old 11-09-2003, 02:11 PM
is there anyone that has put a kit on their car? i was just curious, because no matter where i search for the questions, no one really says for sure if there is a way to NOT cut off your engine when doing this. the reason behind is because i don't want the unburnt fuel killing my cylinders if the engine has to be killed.
what i was thinking is since my car doesn't have catylitc converters, it should have unburnt fuel constantly running out of the pipes nontheless.
Old 11-09-2003, 02:16 PM
poncho62's Avatar
Wiki Edits: 5
When don't they use a "KIT" on those shows. They never fabricated anything on their own on those shows. All that bunch knows, is how to throw money at a problem to solve it.
Ontario Rodders
Old 11-10-2003, 05:38 AM
Re: flame thrower
I believe it only works with carborated motors not computer controlled vechicles. Need to get a build up of raw gas. Ed ke6bnl So. Calif.
