flames on 327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2006, 08:13 PM
flames on 327
ihello ;;i,d like to paint my 327 white with flames all over .any ideas//?? thanks
Old 07-02-2006, 01:28 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
That's an interesting idea - a white 327 with flames all over. I don't think that has ever been done. I saw an orange 327 with orange flames once but you couldn't see the flames.
Old 07-02-2006, 03:30 PM
powerrodsmike's Avatar
Wiki Edits: 161
can you run white oil in it so the leaks won't make such a mess?
Seriously though, oil leaks. that would make me reconsider white as a color choice.
mikey
BE different....ACT normal.
Old 07-02-2006, 10:51 PM
Kallie49's Avatar
I had real flames on mine.....oh wait, thats why I'm rewiring the truck....
in all seriousness, yeah you can do it, I painted my block and trans the color of the truck, took a little time in prep work and was a pain with all the dips and valleys, but came out beutiful! and with the high gloss it is pretty easy to keep clean....the drawback, if you smoke a water pump, ( I was using a stock H2O pump) of need to change something the chips and scratches show lots better than a simple black, good part is you can see your leaks and take care of them
Old 07-03-2006, 06:36 PM
Hey guys, thanks for your opinions. The red flames and white oil gave me a laugh out loud. It's too much time and work for now but maybe next winter when I'm laid off from work and have a garage, I will try it. Thanks again. RC
DZ 302 Vs 327 ???? oc00l Engine 37 11-18-2008 09:53 AM
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
help make my 327 angry!!! 70chevelle327 Engine 41 04-24-2007 05:33 PM
Gloss flames on suede car VWFan Body - Exterior 5 06-06-2005 03:11 PM
Looking to give my firebird some custom flames f355bird Body - Exterior 8 02-03-2005 03:02 PM
