Flames - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2003, 12:04 AM
New Member
Post Flames
What's the best way to produce flames from the tail pipes.
Old 01-15-2003, 12:50 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Smile
go to hot rod search: put in hot rod flame throwers 4 paragraph down Hot Rods Etc.may help,also look in any custom mag. there are kits you can buy,caught something on hot rod tv,they putting in a kit,mount your sparkplugs about 6inches in from end of tailpipe,they drilled and tapped for a heli-coil to thread plug into to be sure plug is in center of pipe,mount the coil as close to plug too,beware of gas tank vents!
Old 01-15-2003, 12:54 AM
New Member
Post
Thanks, and that hot rod show I cought it just in time to see the flame come out. That's what got me thinking about doing it my self. Wished I had seen the whole show.
Old 01-15-2003, 11:58 AM
Post
They have a kit on autoloc.com for about 150.00
Old 01-15-2003, 12:10 PM
Post
check the knowledge base here, i think there are articles about it, or try to find a site called (i think) socheap.com... instructions for a homebuilt system. BE CAREFUL!
good luck!
-z-
Old 01-15-2003, 03:04 PM
5.0Towncar's Avatar
Post
How come you have to buy or make the transistor crap? I don't know much about stuff like that. I'd figure you just run a ground to the coil and run a switched positive to the positive side of the coil and it works. Steve
Old 01-15-2003, 04:41 PM
Post
my buddy tryed that and it made his car run like ****,just buy the kit it will save you time and
and keep you from ripping your hear out
