Flamethrower Exhaust Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2009, 04:07 PM
I have a dual exhaust which exits on the side, before the rear tires and I was considering installing a flame thrower kit.
The thing is, I would only want to use the kit while the car is moving and not have to interrupt the car's ignition system.
I also know that for best results I would need a pair of fuel injectors along with an electric fuel pump installed just before the spark plugs.
I would like to know if there is anything out there that could allow me to shoot flames while in motion and not hinder my engines ignition performance?
Could I make the kit myself or am I better off purchasing one?
Old 08-26-2009, 05:40 PM
The flamethrower ignition does not affect your engine's normal ignition. You want to create a rich mixture in the pipe (using the extra fuel pump and injectors), and then use a spare coil and spark plug to ignite the rich fuel. The normal flow of exhaust gas out the pipe will cause the flamethrower effect as the rich mixture is ignited.
I don't know how the store-bought kits compare to what you could make on your own.
Bruce
Old 08-26-2009, 09:19 PM
Thanks 75gmck25!
How abouts would one go in a home made kit?
I already have an electrical fuel pump and a pair of injectors.
How would I go about the rest?
I imagine that I'd have to purchase a pair of coils, connect the spark plugs to the coils and then wire them directly to the battery. Mount the fuel injectors a few inches after the spark plugs, hook it up to the fuel pump which in turn is connected to the fuel tank. Hook all the electricals to a dash mounted switch.
Do I have it the concept right?
What else should I take into consideration to get the best flames (I've got dual exit 3.5" tips) and not blow my mufflers up?
Old 08-28-2009, 06:40 PM
Take a look at this discussion to get some ideas about how to do it without buying a kit.
http://www.jalopyjournal.com/forum/p...ead.php?t=8017
Bruce
Old 10-05-2009, 09:48 PM
i found these sites both helped me do mine on my 1985 buick riviera with dual exhaust
flame thrower link 1
flame thrower link 2
Restrictive Exhaust Question Regal Beagle Engine 13 08-26-2008 08:17 AM
Exhaust Size Question: 2-1/2" or 3" leejoy Engine 4 08-14-2008 06:32 PM
Exhaust System Question - Best Method leejoy Engine 12 08-14-2008 01:19 PM
Exhaust question for super/turbo members jameskirk1 Engine 7 08-18-2005 07:58 PM
exhaust cut-outs question bigpapagun Hotrodding Basics 8 01-27-2005 04:01 PM
