Flanges on 4160 Holley's the same as 4150's? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2004, 08:16 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
Just curious if the 4150 flange is the same on the 4160 carbs. From what I have read, the 4160 can be converted over to become a 4150...so I'd assume they have the same mounting flanges...
input? basically hoping that I can get ahold of a 4160 for cheaper than a 4150 or a demon for the time being. I have about a million things I need to get ahold of to get my truck on the road and it's all building a big mountain against me
found out the work on my heads is going to run me 740!
new valves, new seats, new guides, pocket porting, 3 angle job..blah blah blah, cleaned, magnafluxed.
Old 06-28-2004, 08:35 PM
BOBCRMAN@aol.com's Avatar
The plates look physically the same. The difference is in the metering and transfer holes cast into the bottom plate. They have to line up with the body.
Old 06-28-2004, 08:36 PM
unstable's Avatar
Murderator
I'm tarded Bob.
I guess what I'm asking is...if I have an intake that is 4150 flange, can I put a 4160 on it?
Old 06-28-2004, 08:43 PM
YES
Old 06-28-2004, 08:45 PM
unstable's Avatar
Murderator
Thanks. Like I said. I'm tarded.
Old 06-28-2004, 08:54 PM
lluciano77's Avatar
They share the same bolt pattern.
A Holley 4160 has one metering block. 4150s have two. That is the only difference between them.
