Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - flare fitting needed
Old 04-25-2011, 09:32 AM
Jim Rockford's Avatar
Jim Rockford Jim Rockford is offline
World Famous VF-14
Last journal entry: Cleaned it up...
If it doesn't leak after its installed, its not just gonna spring a leak because you bought it at lowes or HD. if it works at the start it will continue to work after, Unless the so called inferior brass,( that is made by the same overseas company that make the same fitting for NAPA ) suddenly shapeshifts and springs a leak, In either case its not gonna just fall off going down the road. Geeze its no wonder this country is on the skids, Its full of sissies.
