flare to flare elbow fitting - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2008, 07:14 PM
GMR GMR is offline
I have a sbc 350 and am using a stock mechanical fuel pump with 3/8 inverted flare female fitting on the output port. It's a Carter pump purchased at NAPA.
I found a brass flare to flare elbow fitting with 45* flare male threads on each end. It's made by a company called WATTS with a part #A-169.
Can I use this elbow between the fuel pump and a 3/8 steel brake line which has a female tube nut.
http://www.watts.com/pro/searchresults_paging.asp
Let me rephrase the question.
First off, if you click on the link and enter the part #A-169 in their SEARCH it will show you a picture of the fitting in question.
I know that an SAE 45* flare female fitting has a 45* angle and an SAE 45* INVERTED flare female fitting has a 42* angle.
What's the difference between their male counterparts, since each of the males has a 45* angle?
To Flare or Not to Flare ? DrBee8457 Engine 6 06-19-2008 06:18 PM
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 04:12 PM
"Basics of Basics" Trial fitting parts MARTINSR Body - Exterior 4 02-23-2008 09:33 AM
Steering Hose and Fittings bartamos Suspension - Brakes - Steering 15 05-27-2007 03:08 PM
water pump fitting leaking brian400ex Engine 4 03-22-2003 05:06 AM
