To Flare or Not to Flare ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2008, 04:17 PM
Last journal entry: It's getting there
I'm running hard line (fuel) from my carb to the fuel pump. I'm using an Edelbrock Filter with -6AN fittings. I'm using a Russell compression fitting to connect the filter to the hard line. The question is do I need to flare the hard-line or will the compression fitting do the job.
I assume (there's that work again) that if I have to flare, I will need to use a 37 degree flare because it is an AN Fitting.
Any help would be really appreciated.
Old 06-10-2008, 05:00 PM
I had the same issue and I went and bought a good 37 degree flaring tool.
Works great ... and makes the connection leak free but still serviceable. You can take it apart and put it back together ... with no leaks.
Old 06-10-2008, 05:12 PM
re:To Flare or Not To Flare
Thanx for the quick response. That's the direction I was leaning, but if I come home with one more tool I'll be sleeping in the garage. Although Father's day is this Saturday ....hmmmmm
Old 06-10-2008, 05:22 PM
My wife says I never met a tool I did not want to own.
I shopped online and found a Imperial brand 37 degree flaring tool for cheap money. I got mine off eBay ... for about 1/5 of the new price. I see them for 10 to 15 dollars ... every now and then.
But I was in NO HURRY ... I borrowed a friends a couple of times ... and seen the need ... so I just watch and waited until a good deal came along with low,low shipping.
Old 06-10-2008, 11:42 PM
Thanx for the tip Deuce
Old 06-19-2008, 05:52 PM
A man can NEVER have too many tools ...
Old 06-19-2008, 06:18 PM
biggeazy-e's Avatar
What model number is that flaring tool? I've been looking at them for a little while now..
Double flare brake line problems highway 1011 Suspension - Brakes - Steering 8 10-21-2008 11:47 PM
Single flare Brake Lines homesimpsonr Suspension - Brakes - Steering 2 03-20-2008 07:40 PM
double flare 67chevy Suspension - Brakes - Steering 1 11-13-2006 03:05 PM
Flare tool choices for hobbyist BIGSKY Garage - Tools 10 11-27-2005 07:04 PM
Double Flare Postscript Centerline Suspension - Brakes - Steering 6 03-06-2002 04:58 PM
