Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flaring SS Brake Lines for AN Fittings
Old 05-01-2003, 07:36 PM
32vicky's Avatar
32vicky 32vicky is offline
Tomorrow Will Be a Better Day
<a href="" target="_blank"></a>
These seals are a pretty simple concept. They are basically a thin (.010") aluminum preform. They aren't a compression fitting, but rather a thin layer of aluminum that fills in the imperfections of the flare when the fitting is tightened.
I have them installed, but didn't have time to try bleeding the brake system yet. I pumped them quite a bit and didn't have any leaks. Once I get all the air out, I'll know for sure.
It should be noted that these are used for aircraft line repair (commercial, private and military).
