Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flaring SS Brake Lines for AN Fittings
Old 05-10-2003, 08:25 PM
ibuildm ibuildm is offline
New Member
We use SS tubing only at my shop. We single flare whether using inverted flare with 45 degree flares or AN with 37 degree flares. Stainless steel does not split when making the flare like regular steel brake tubing does if not double flared. On occasion we have a leak problem and to solve it we use a cup shaped copper sealing washer that we get from our local hydralic hose and fitting supplier.
