flaring Stainless (tips, tricks)
I did my homework, bought the right tools, and thought I had my bases covered. I guess I was wrong. The 37-degree flares all want to split... badly. Is it cheap tubing, or am I doing something wrong? I got a Ridgid flaring tool rated for stainless, and the Ridgid tube cutter with blades rated for stainless. I think out of 10 flares I got a couple that were possibly usable. I searched this site for techniques on flaring SS, but didn't find anything.
If I can't get the stainless to flare, can I use 37-degree flares on regular steel lines? And just to answer the obvious next question, I have all the AN adapters and tube nuts with sleeves.
Join the club...........I never could get Stainless to flare on a consistent basis either.... .
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Use a long taper ream to deburr the inside of the tube. Chamfer the outside of the tube at 45dg for half of the tube sidewall thickness with a file, fine stone grinder, disc sander or a chamfer tool (prefered). Lightly sand the end of the tube to remove any sharp edges. The preform length is critical. Set it very carefully. Put a drop of light oil (must be cleaned off tube after forming operations) on the preform die, center carefully and seat fully to the tube holder. If the die doesn't set flat on the holder after preforming, either the chamfer wasn't centered(usually) or the preform length was too long . The final form will be painless. Another drop of oil on the swage, center the die and complete forming. Turn the swage down till the flare is JUST folded in. This doesn't require a lot of pressure. Overforming is a sure way to split or otherwise ruin the flare.
Doesn't hurt to oil the swivel in the swaging tool and the rollers and blade in your cutter occasionally to. Dont cheap out on your brake tube. This isn't the place to be saving pennies. I personally won't use stainless brake tube because I have concerns about the brittleness of it. Note how easy it splits. Probably fine for trailer queens but not for a driver. FYI To do your bends. Adapt you portopower pump to fit the lines. Fill the lines with oil. Be sure all the air is out, cap the line an pump that sucker up. I pump till the pump bypasses. You can now bend the tube just about any way you want to without fear of it collapsing. After bending, wash out the hydraulic fluid with a no residue solvent like John Deere parts cleaner. |
I have seen advertisements for fully annealed stainless that is supposed to be able to be double flared. I guess the metal is less brittle. I am planning to try heating the tip just prior to flaring with a portable torch. Or I will just bend it all up in regular tube and have a pro flare up some stainless. This won't be a trailer queen, but I wanted this to be a nice touch to the car. I don't see why I can't do AN fittings with the regular metal tube. The tube nut and sleeve I got for the stainless should give enough support to the flare to make it even more stable than a double flare. What is the main issue with using this kind of tube and an AN fitting? Is it the seam? |
stainless
I don't think heating up the tubing is a good idea. SS specialties sent me a remote fill kit with double flared stainless. I have gotten stainless from a number of sources in the magazines, Pure Choice is one; www.performanceplumbing.com- maybe they have some info that will help. I've never had a problem with the an fittings/single flare, I drive them daily, been using it for 20years. Right now I'm thinking it must be the tubing. You'll get figured out, don't get discouraged. Bill
I had nothing to loose but to try heating the ends. I also took the advise from the the other posts, and in combination, I got the flares I wanted. The heating really helped. So if the tube I got is overly brittle, then heating it really helped. I simply used a plumbers propane torch for about 30 seconds, until the about 1/2" turned cherry red, then flared it. Not a single split was seen. So I am guessing the tube you use is already annealed, I just had to do it myself. Thanks everyone for your advice and encouragement. I just hope the lines don't leak. ![]() Make sure to check out my site www.project-quicksilver.com. The car and everything I have done to it is documented there. |
I also found these little conical seals made by Earl's. From what others are telling me these are better than the brass ones people have been using so there won't be any electrolysis issues. One guy I spoke to on another forum swears by them. May not be just the item that people need to help solve the problem of leaks.
conical seals
I have always used annealed seamless tubing and never had a problem.
The other thing is I never use a tubing cutter. Stainless steel work hardens and if you use the tubing cutter it will work harden the end of the tube. I use a hack saw to cut the tube and then a disc sander to square the end. A slight chamfer on the inside and outside (inside with a cheep 45deg chamfer bit in a handle and a file for the outside). I have never once had a problem with the flare. |
Stainless anneals different than carbon steel. While you reduced the yield strength by heating it, allowing it to be flared while still hot, you may have made the tubing brittle in the area heated. Proper annealing of austenitic stainless (304, 316, 18-8, etc.) involves heating the metal to 1900 - 1950 deg. F and then rapidly cooling it. You must drop from 1950 to 1100 in 3 min. or less and continue that cooling rate until 800 is reached. Whether you did this or not probably depends on how hot the flaring tool became during the flaring process.
| Bulet proof 406, tricks and tips? | wayfast77 | Engine | 6 | 09-02-2005 10:43 PM |
| Flaring Stainless Steel Lines | blacklotus | Suspension - Brakes - Steering | 8 | 03-20-2005 07:52 AM |
| Tips and Tricks | Nightfire | General Rodding Tech | 5 | 12-02-2004 08:46 PM |
| TH350 tips and tricks | Big86inthestixx | Transmission - Rearend | 5 | 11-21-2003 09:20 AM |
| Tips and Tricks wanted | creeperrage | Hotrodders' Lounge | 0 | 10-30-2001 07:13 PM |
