? on flash rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2010, 06:34 PM
? on flash rust
the car is down to bare metal, i have to clean it yet with wax and grease remover,then put on a metal cleaner, my ? is will the metal cleaner slow down any flash rust befor i spray the epoxy primer on, its been a little hot and humid here in Mich, so im waiting for the temp to go down some. im using PPG products, the tech sheet says after metal cleaner to use metal conditioner the guy at the paint store said i really dont need to
, thank you for your in put
Old 07-18-2010, 06:02 AM
deadbodyman's Avatar
Wiki Edits: 11
metal cleaner wont help....Its a common problem when stripping a car...I use Ospho on all the cars I strip ,if its inside it wont get surface rust ,if it already has surface rust it'll get it right off...I've used it for years ...use wax & grease remover first.. theres a lot of threads here just do a search on "ospho" for proper use ,it'll bite you if its not used right...
Old 10-03-2010, 10:14 PM
i use tnt stuff called anti rust spray it on and before you prime wie it off work for me
I think there website is tntrustremover.com
Flash Rust Help!!!! 71haulnazz Body - Exterior 4 12-12-2008 05:03 PM
65 f100 and the battle of rust. z chrome rust defender? 65fordguy Body - Exterior 3 08-03-2008 04:16 PM
Rust inbetween Double Seem Questions Advice on ATTACK Plan fcastro Body - Exterior 3 01-21-2008 11:20 PM
Rust Spots WildBill Body - Exterior 3 11-09-2007 06:22 AM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
