Good Lord, I've created a monster. I don't think anyone out there
is reading what the other is saying. I only read one response that comes close to my question. First of all, yes a overall paint job is "one" paint job. that is not the same as the second coat becoming "one" with the first. Lacquer does this, it melts the previous coat and if you looked at several coats under a microscope they would look like "one" coat. period! base coat and clear coat stay separate, they may be stuck together but they're still separate. Thay can be parted. And sometimes they do. Second: When I asked about flash time I'm not asking when I "can" recoat. I know that, it's right on the can 30Min to 24 hrs. What I'm asking is when is the best time. The best time won't be feasable for the production shop, that's not me. If waiting 2 hrs is better than 30min I will do that. To me, the more dry the base the better I would think. within reason of course. It may be dry enough at 30 min but remember, that's the minimum! I don't want the minimum or the maximum. Maybe the middle is best? 12 hours. I know this is a moot point that none of us will do but think about it. 30 min dry may never give you a problem but does that really mean that it's the "best"? |
Barry, yeah, S-W had a seven day max recoat time on the UltraBase. Go to the bottom of the second page HERE .
Not really a problem,
because of its enamel makings! It could really go longer as long as not activated maybe even 60-90 days-(just guessing) the biggest concern would be how long you can go before this base sensitizes itself. You want the clear applied before that happens to prevent lifting. Every system has its positives and negatives, and this is a positive no doubt. You can bet, if SW says 7 days the sensitivity does not kick in for 14 days or so. Last edited by BarryK; 12-18-2004 at 12:09 PM. |
Martin, I've painted lots of cars with only a box fan for ventilation, the only problems I had was trash, bugs, etc. The only times I ever needed a paint rep was for color match problems.
I agree with most of what you say, except the statement about more problems with peeling because of cc being applied to soon and I agree with that, if there was not enough flash time, if you wait for the recommended flash time, there should be no problem. As I never kept a chart of the times I've waited for flash, and I've never had any problems except when waiting to long. So in my opinion the sooner you cc after you get a flash and the air has cleared, the less likely that there will be any problems with adhesion. As far as sniffing the bc after the cc has peeled, it would be hard to tell the difference between thinner and paint. I have learned over the many years in the business that not many shops or painters do it the same, this procedure has worked for me quit well. Troy __________________ If you don't make mistakes. your not doing anything. 69 SS/RS full custom Camaro 98 ISCA Grand Champion 69 SS/RS BB Camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 SS Chevelle BB conv.fresh frame off 26 T sedan street rod |
Sorry for the confusion, but you said you read one post and now you have other questions. nasty or not this has covered some very good and important ground. (there will always be different opinions some fact and some hearsay) Everyone of your questions has been answered! So read all the posts and pay attention about the graph as that is how companies decide how to set the wide rage of open-coat, and use common sense with the graft and all your questions will be answered. Barry |
I've cleared S-W base that has sat for more than 7 days with no problems BUT it was on helmets that had multiple colors and they are still fine today , a car with all the everyday conditions would probably be different.
jcclark , If I were you ,being that you are doing this in less than optimum conditions , I would base it the one day , than go ahead and clear the next . If you have any doubts whatsoever , maybe go over the car quickly the next day with a grey scuff pad to just scuff it a bit . Last edited by outlaw17; 12-19-2004 at 09:36 AM. |
You really shouldn't scuff the base. You "can" do it, but it opens up a huge window for problems. Some bases are very sensitive and marking or scratching will uccur that the clear won't hide.
If you do scuff it is usually a good idea to apply another coat of color. Like I said, you can scuff some bases, but some you can not. |
MARTINSR I would assume has a bit more experience than me so ya better listen to him . I have had no problems doing it the little bit that I have but I also have never had anyone tell me not to do it up until his above post . You learn something every day here at the Hotrodders forum
I've always had to spray more base if I scuff. It always changed
the appearance when I scuffed. Just this past Sat. I sprayed 2 fiberglass fenders with black base and it revealed a lot of scratches in the primer. I scuffed with a gray pad untill they were gone, sprayed a couple new base coats and it looked perfect. I waited an hour to clear and then long enough between coats that it was well flashed. The temp was less than 50 deg. (I used the coldest thinner) It took me a total of 6 hrs. But waiting longer between coats really gave me a better finish. I had less dye back, a smoother finish and it didn't tend to run. It was my best ever. After they "set-up" I brought them inside to warm and cure. They look great. I'm going to start waiting longer between coats. I have been just to impatient in the past. |
OK now I have a question, If you spray(BC?CC) at less than 50 deg. how long can you go before bringing the temperature up high enough to properly cure? Also would a brief exposure after spraying of about 10-15 minutes to even colder temperature cause any problems? Cold temps are problem for me right now.
Base is a different issue.
If at all possible pre warm the metal to 65-75 than shut off heat and spray. Word of caution is, if metal is cold and you apply your coats than turn on heat solvents will trap in coat closest to metal. Thats why preheating is most important. When you apply heat after done, is really not an issue but make sure you give it longer than normal before clearing. This would be a good case for letting base set over night before clearing. Also this would be a time Not to use an activated base for best results. |
