flasher for turn signal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 03:56 PM
Last journal entry: done as of 9/10/08
i am having a problem i hope some one can help me out.
the problem is when i turn the left or right turn signal on the indicator on the dash both light up and flash.
this is on a 1955 thunderbird 6 volt pos. ground system and i replaced the flasher with a new one, the terminals on the new one have 3 posts and they are marked with a (p) (L) (x) the old one had 2 posts but the book call's for this part i hooked the wires up to the (L) and (x) the turn signal works ok but the lights on the dash are both flashing could you please let me know what i am doing wrong.
thank you for the help
rick
Old 06-08-2008, 05:23 PM
T-bucket23's Avatar
Wiki Edits: 26
rick
I quick guess is someone rewired the brake lights at one time and did it wrong. Do yhe lights on the outside of the car flash properly.
Old 06-08-2008, 06:02 PM
yes the out side lights work the way they should it is just the inside lights that are the problem they both flash at the same time.
Old 06-16-2008, 10:48 AM
if they are on the wrong post on the brake switch will that cause the problem or are you talking about in the back at the light it self ?
i do have a burnt bulb on one side of the tail lights will that cause the problem?
thank you for the reply
rick
Old 06-27-2008, 08:45 PM
checked the weiring for the stop lights and turn sig.and see no problem with the wiring.
any help would be grate i am still having this problem and have looked at just abut all the wirering
Old 06-27-2008, 09:04 PM
Wiki Edits: 31
mismatched taillight bulbs can backfeed like that
Old 06-27-2008, 09:08 PM
both tail lights are the same and one of the front lights are for sure but one of the front lights i am not sure of but will look at them tomorrow i am using 1154 lights in all the turn sig. and stop lights. and parking lights
Old 07-11-2008, 06:42 PM
looked at them and all are the same i have no idea as to what is causing the problem.
i did notice that the blinker switch will make noise and the lights on the dash will only work (both at the same time) when turning the right hand signal on if using the left hand signal there are no lights on the dash but you can here the blinker switch working and the lights work.
have looked all over the wiring diagram and can find no problem also checked the wiring in the car i have run out of idea's hope some one here can give some advice
Old 05-20-2009, 09:08 PM
still having a problem
i have run through every thing i can figure to be the problem and still have the dash light (turn ind. ) both blinking the outside lights work properly can anybody help me out ?
thank you
Old 05-20-2009, 10:13 PM
Joe G's Avatar
Rick,
I would bet money that the problem is a bad or missing ground to the turn indicators in the dash. The turn indicators seem to be back-feeding each other. If everything is wired correctly, this is only logical explanation I can think of that would cause the symptoms your car has.
I'm not familiar with the layout of the instrument cluster on your Thunderbird. Are the turn indicators in the main cluster? If so, do your instrument lights and high beam indicator work?
Hope this helps...
Joe G.
Old 05-21-2009, 10:12 AM
bobjob's Avatar
i'm guessing it's the turn signal switch cam plate? not too hard of fix if so.plate is around $10.00- would have to remove batt. cable 1st,-remove steering wheel-unscrew turn signal lever-remove 3 philips screws- and change out plate.(you would also need a steering wheel puller $17.00) still cheeper than taking it to a shop (around $70.00) or more.
TRY FIRST-- flasher with 2 posts if thats what you had in it originally.
'55 was a long time back.a lot of signaling, i had this problem a lot with school buses that were only 5 years old.
Old 05-21-2009, 11:41 AM
thank you both for the reply i did check the dash lights and the high and low beam ind. and they work i have not got the inside map light to work yet but i think the bulb is shot.
will try pulling the steering wheel off and see if i can replace the turn signal gear there.
this will take a while so will get back to you when i get this done.
i did paint the car could it be a ground on the turn signal light housing it self?
(even when the turn lights and stop lights work )
thank you for your help
turn signal flasher coolcars58 Electrical 2 01-22-2009 08:26 PM
Turn signal flasher question sexypizzaman Electrical 2 09-20-2008 09:59 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 07:23 PM
Turn signal flasher Seon Electrical 10 12-05-2003 11:34 AM
