Flasher wiring (colors codes) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2008, 11:00 AM
Hi guys, does anyone know what's the function of each wire of the steering column (flasher unit) for a 86 Firebird. There was 10 wires: white,dark green,yellow,purple,brown,dark blue,light blue,black,light green and tan.I want to fit it in a hotrod. Thanks for all.
Old 06-02-2008, 04:15 PM
Hoptup32's Avatar
GM Steering Column wiring
White - Stop Light
Green - Right Rear Turn
Yellow - Left Rear Turn
Purple - Turn Signal Flasher
Brown - Hazard Flasher
Blue - Right Front Turn
Lt. Blue - Left Front Turn
Black - Horn
Green - Ground
Tan - Ground
Additional Wires with Ignition Switch in Column:
Orange - Ignition Switch
Red - Battery
Brown - Accessory
Pink - Coil
Purple - Starter
Old 06-03-2008, 10:49 AM
Thaks a lot, you same me lot of time.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Yankee turnflex TURNSIGNALS 730/6 wiring again? cadipacer Electrical 1 07-06-2006 06:13 PM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
1956 chevy belair Wiring Diagram NAK Electrical 1 05-12-2005 09:22 PM
Anyone have 4L80 chassis wiring diagrams Jason Transmission - Rearend 24 09-18-2003 02:58 PM
