Doc here,
You might try and inspect the plug on the DRL, and the pins on the edge card connector, For burned , bent corroded or Ill fitting plug. Clean Burnish the plug and connector pins CAREFULLY, and check the grounds. If good, the DRL may be on it's way out..(they may be a BCM code for it). As always, we assume you have already checked and cleaned power and ground connections at the battery, and device (s)..and is good. You might want to run a ground from the alternator to the ground buss system also. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Daytime running lights--Doc---are you refering to a module or relay somwhere?
Doc here,
Yeah, there should be a module somewhere in the lighting system for the daylight running lamps..maybe even part of the BCM, (body control module) What he needs to do is get a Manual at the library or buy one that has locations for the modules. Doc
| voltage to tail lights vs brake lights? | stratt134 | Electrical | 12 | 06-10-2006 06:51 PM |
| How to convert to flashing hedlights instead of turn signal lights!! | willys36@aol.com | Electrical | 5 | 08-11-2004 07:16 PM |
| LED Lights not flashing? | Siggy_Freud | Engine | 2 | 04-04-2004 10:02 PM |
| Wiring Tail Lights & Turn Signals | horvath | Electrical | 15 | 04-30-2003 05:04 AM |
| Back Up Lights - how to choose? | horvath | Body - Exterior | 6 | 03-04-2003 03:20 PM |
