Flat black - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-20-2010, 09:04 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: not much new....stole wifes spot for now
I recommend smartshoppersinc.com also. good prices,great service and prompt shipping...
  #17 (permalink)
Old 05-20-2010, 01:50 PM
RattVette's Avatar
Originally Posted by casehd
I can`t comment on the price, as I haven`t really done alot of paint or body. The quart "kit" with the reducer and catalyst is $89 at my local parts store.
Is that pricey? What is the average cost of the John Deere paint, anyone know?
$29.95 for a gallon of Blitz, quarts are $11.95 only took one quart to paint the vette hardner is $14 naptha for thinner/reducer is usually $7 a quart
  #18 (permalink)
Old 05-20-2010, 02:07 PM
Wiki Edits: 31
where I live, JDBB is $50+ per gallon from the dealership.. it's expensive enough, that it's more cost efficent to buy 'real' paint.
Restoration shop/ Kustom Shop Hotrod Flatz, is urethane single stage and a gallon kit and can be had for $149 for everything
  #19 (permalink)
Old 05-20-2010, 03:14 PM
RattVette's Avatar
Ouch talk about double charging you, do you have a TSC store (Tractor Suppy ) they sell the Low Gloss Black made by Valspar for $29.99 a gallon same paint different label as they are the producers of Blitz Black)
  #20 (permalink)
Old 05-20-2010, 05:07 PM
Underground's Avatar
Last journal entry: 54
Everything "John Deere" is double charged!!
  #21 (permalink)
Old 05-20-2010, 05:37 PM
Blitz Black is the way to go...couple years ago it cost under $100 to do the whole car....I think the blck was under $30 a gallon , plus a lttle thinner, I suggest you do a 'search' here at hot rodders and read up it.
  #22 (permalink)
Old 05-21-2010, 09:48 PM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by Underground
Hey DON'T apologize to me. I don't care what people use. I was making the comment on KIRKER being real paint. It was a joke. I personally don't like the flat black look, been done WAY to much. Urethanes are the ONLY way to go, in my opinion. You could also look into Hot Rod Flatz. They have tons of cool colors. But like was mentioned earlier. Just buy a cheap urethane and add flattener to it. Then you can have ANY color you want.
Only a urathane ,anything else is a waste of time and money. if you want cheap use laquer primer but it wont last ...it will hide a lot though....for about 50.00
nason black urathane runs about 150.000 it'll hold up for 5-10 yrs
  #23 (permalink)
Old 05-23-2010, 07:07 PM
S10xGN's Avatar
Gotta love a turbo!
I've used it, sprays great. Look here for further info...
Russ
  #24 (permalink)
Old 05-23-2010, 11:39 PM
Blitz black.
Granted, I am not a body man or painter, however I have sprayed two vehicles with John Deere Blitz Black. Did it outside with a primer gun. Both turned out very nice. It was almost impossible to screw up! Paint is very durable and did not fade even in 100 degree heat and direct sun. Not show quality, but it works and it is easy to apply. I really don't know jack about painting but I can read. Real simple for low budget. P.S., I always use some type of resperator or filter, even when spray painting. Safety first.
Flat black TwistedTrbl Body - Exterior 5 03-27-2006 11:03 AM
Flat Black Paint sully Body - Exterior 11 01-14-2004 04:19 AM
Flat Black Paint trick66 Body - Exterior 10 03-15-2003 05:13 PM
