flat black - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2011, 02:46 AM
flat black
whats a good flat black to use i bought junk at a local auto paint store a gallon for 45.00 it looks like tar coming out of the can, have to cut 1-1 ratio then says put on 3 coats and wet sand with 220 grit i never had to flatten a primer coat with 220 what else is out there
Old 05-16-2011, 04:15 AM
get normal waterbase black base coat, apply three coats then clear coat it, but add matting agent to the clear coat. simple
Old 05-16-2011, 07:50 AM
Or get a "Matte clear" that is already flattened and use it. I am with the previous poster that is the best way to get a low or no gloss paint these days.
Old 05-16-2011, 09:18 AM
TucsonJay's Avatar
You can also ad flattener to single stage. I've done a couple '32 Fords that way, and one still looks good after over 10 years.
Just don't use primer. I have seen black epoxy primed turn gray with white streaks after three years.
Old 05-16-2011, 10:35 AM
67Elcamino's Avatar
I have a 64 Cadillac (see my profiler) shot with everything imagineable DP90, Poly Primer, Euro Primer, House paint, fence anti-rust paint etc.. etc.. about 10 years ago and little monye trying to get that satin finish. all of the above mentioned faded or chalked 6 months to a year later.
The last time about 5 years ago it was shot with PCL flat black and PCL Flat clear. Love the satin finish but the person shooting got help from PCL. He mentioned he had a hard time getting the tiger stripes from shooting the clear. As far as durability Ive left it in the sun for a couple of years and since always bee stored outside with a cover. No change to the paints finish.
Had a buddy with a 61 Cadillac. The same painter with PCL flat black no flat clear and the car is beautifully perfect satin black...he has had it for 5 years this way Hes kept it outdoors but with a cover. Drives it alot goes to out of town car shows and no changes to the paint finish. I cant remember if the guy that painted it says he had someone from PCL actually shot it or just helped him..
I guess my car was used as a ginuea pig. hahaha.
Case in point if going flat black do not use anything but flat black paint or flattened clear to get the rich solid flat black finish
Flat black swvalcon Body - Exterior 1 11-10-2010 07:39 PM
What's the difference between flat black and matte black STATUTORY GRAPE Body - Exterior 10 08-07-2010 07:37 PM
black trim re paint questions, flat or gloss black? tiptopss Body - Exterior 5 04-11-2010 09:51 AM
flat black hood on a gloss black car Dubz Body - Exterior 23 07-14-2004 08:01 PM
Flat black! The best looking yet!!! daimon1054 Body - Exterior 3 02-06-2004 04:42 PM
