I am looking to paint my motorcycle with flat black paint! I have seen a few finishes on new bikes with a flat but not like primer flat finish. Lets call it satin! Any one no where i can find this type of products and tips for refinishing myself?!
Thanks
I used John Deere blitz black, but if you decide to use it you'll have to go to Nevada to get it, it's illegal in CA. Or you could just buy a regular paint and have it flattened a little.
Originally posted by drgnwgn289:
<strong>I used John Deere blitz black, but if you decide to use it you'll have to go to Nevada to get it, it's illegal in CA. Or you could just buy a regular paint and have it flattened a little.</strong><hr></blockquote>
Thanks, what kind of paint is the John Deere stuff? Why illegal? Where can i get it from? any one online that will ship to Cali.?
[ February 24, 2003: Message edited by: sully ]</p>
Even though I like the JD Blitz Black, I would suggest using a catalyzed paint with flattening agaent added, that way you can get the right ammount of gloss and it will hold up better.
I used dupont centari acrylic enamel. Add a flattening agent to it in varying quantities to achieve the desired result. Any paint shop will be able to provide you with the correct agents. I can get the # off the can if you would like.
Sully and Trick66... (from post "John Deere Blitz Black")
It sprayes like any other paint with the proper ratio of reducer and such. Use a JD primer to shoot over existing paint or bare metal. They sell JD BB and primer in spray can size so you can experiment with varied primered or bare metal surfaces.
A clear Coat cant be used for the Blitz Black unless a flattening agent is mixed in. And it defeats the purpose if a clear is applied. The JD BB is widely used for the satin/suede/flat look as seen on old school Rat Rods & Rods alike. And its $$.$$ instead of $$$$.$$. Take a look at Jesse James ride the 54 Chevy ****initupagain as seen on the new Auto Zone TV add, and on the WCC site under "Whips" http://www.westcoastchoppers.com/. I called House of Kolor and talked to "the man", they use a HOK black (or any PPG black) with a HOK (or any) flattening agent. to get the flat look for the 54 and his other rides. The purpose for the JD BB is so the car will have the unfinished "look" of a flat black primer yet have a skin on it that you can beat the piss out of and it will stand up. And for pennies to repair compared to others. It is also has a good UV blocker and will hold up to any weather. Where a bare black primer will soak up water and oils. There is another option that is probabally the best flat black coating Ive found. And its pricey. By Color-Rite. http://www.color-rite.com/ Its called Asphalt (#MQ2818) and the Egg Shell (#P-FKT600) clear coat kit for it. It is the best looking true flat black Ive seen. And its strong. Honda put this color on its 03' 919 Motorcycle if you want to look at the color and finish.
I did a bike tank not long ago and needed it to hold up to gasoline. I ended up useing PPG's Flat n Flex DCU 2060 with hot reducer over Sem's trim black . It took 3 days to lose it's gloss so be patient http://www.pwpaints.com/images/downloads/dcu2060-p-217.pdf
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
