flat black questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 12:00 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
I've got a few questions about flat black paint.I know there's a few diffrent options so I figured Id ask&see if I could get a few diffrent opinions.I've been using this lacquer flat black a lot lately but there's two things that I don't like first it scratches very easily next if anything touches it that has some sort of dirt I it ,it shows.Makes me think of a cardboard that's pretty much how the panel looks&feels after its cured.
I know some guys use a base or singles stage with a flattening agent I'm guessing that has to be more durable but how will it lay?I like how this flat lays as it seems to be a zero chance for orange peel,it lays like base or primer so I'm hopping something else will lay like this also.
Old 04-13-2013, 12:19 PM
put up or shut up
if you're using lacquer and are ok with it other than the scratch then I'd consider hot rod black before a 2 stage and flattener. Obviously not gonna be as durable as a two stage but it's cheaper and a lot more durable than lacquer.
Old 04-13-2013, 12:27 PM
Old Fool's Avatar
I suggest you try the SPI HotRod flat black single stage .
You can vary the sheen from satin to flat by changing the amount of reducer you use. Sprays out without tiger stripes, even I can shoot it without messing it up, LOL.
SPI Hot Rod Flat Black info
Old 04-13-2013, 12:36 PM
put up or shut up
that's a VERY good point about the tiger stripping. Never sprayed the SPI version but have had that issue with overlapping around door/quarter edges with the hot rod black. Great input.
Old 04-13-2013, 12:43 PM
two cups of tea
Wiki Edits: 2
69 I've looked@summits hotrod satin black I guess what I need to know is does it lay flat like the lacquer?I mean that stuff lays smooth kinda fool proof ya know?
Old 04-13-2013, 12:44 PM
two cups of tea
Wiki Edits: 2
thanks Ill look It up
Old 04-13-2013, 12:50 PM
two cups of tea
Wiki Edits: 2
this flat that I'm using I've never had tiger stripping with its been well to me&people seem to like it its just like I said it lays just like base&has the same feeling as base.I'm debating on dealing with it or not I'm gonna have to order a few quarts of some other brands don't wanna miss out on something I might like better
put up or shut up
nothing will lay as good as that stuff but that's cause nothing's there. I tell you though, it will lay good with a decent gun and tip.
Old 04-13-2013, 01:30 PM
Bc/cc with a satin clear is the ONLY way I would do an exterior flat color.
Old 04-13-2013, 01:38 PM
two cups of tea
Wiki Edits: 2
what do you mean nothing there?What's a matter with this way?
Old 04-13-2013, 01:54 PM
I wasn't knocking your work. I am only saying that flat SS colors are very delicate and damage easy. A flattened clear over a basecoat gives you the same basic look but with a lot more durability. Not as much as regular high gloss clear coat, anything flattened will be more temperamental but the flattened clear is a lot more durable than flattened SS.
Old 04-13-2013, 02:34 PM
two cups of tea
Wiki Edits: 2
I got ya I thought the picture wasn't showing up.I was hoping the single stage would lay like what I'm spraying now.
Old 04-14-2013, 05:01 AM
da34guy's Avatar
Shot the SPI Flat black @ the 4 to 1 mix ratio.
Lays down like silk and is bullet proof.
Best on the market IMO
Won't ever use a flattened clear again.
Old 04-14-2013, 07:48 AM
the last time i used lacquer i was painting my dinosaur while listening to an 8 track tape
Old 04-14-2013, 09:16 AM
TucsonJay's Avatar
I have painted hundreds of bikes. My first worry would be that gasoline will attack the lacquer much easier than a urethane with hardener.
I've used both, and the urethane is much more permanent. I like to do things one time, and never have to worry about it again.
What's the difference between flat black and matte black STATUTORY GRAPE Body - Exterior 10 08-07-2010 07:37 PM
Flat black 51chrysler Body - Exterior 23 05-23-2010 11:39 PM
black trim re paint questions, flat or gloss black? tiptopss Body - Exterior 5 04-11-2010 09:51 AM
Flat black TwistedTrbl Body - Exterior 5 03-27-2006 11:03 AM
flat black hood on a gloss black car Dubz Body - Exterior 23 07-14-2004 08:01 PM
