Flat head and a T-5? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2005, 05:54 PM
2NDXRND's Avatar
Catherine Bell digs me........
Anyone have any knowledge on this combo? Well, I'm getting ahead of myself. Lemme 'splain!
I'm looking into a '36 Ford P.U. project. No engine/tranny. I have a line on a '50 flat head, I already own a '89 T-5 5-spd. I heard/read a while ago that someone makes an adapter for putting the T-5 behind a flat head. Has anyone else heard of this? Any web sites or other forums I should join?
Old 11-09-2005, 09:41 PM
powerrodsmike's Avatar
Wiki Edits: 161
Wilcap mfg makes a nice adapto-kit for that one. I just used one to put a tremec 3550, ( very similar to a T-5),behind an 8BA flatmotor in a 48 C.O.E. The part was top quality as were the throwout bearing adapter and hardware. you will have to make up a new rear mount adapter, move and modify the stock crossmember, or use a universal crossmember. The shifter in the cabover had to be relocated because tremec shifter was too far back. I think that one of the mustang places like Mustangs plus can help with that if you need it. Looky here: http://www.mustangsplus.com/Merchant...Code=new_items You will need to get a clutch disc made special because the flathead flywheel does not have the depressed center to clear the damper springs like the later stuff does. We had Superior clutch in San Jose Calif make it up for us. The pilot bushing and the stock pressure plate worked ok but we still had to turn a slight relief in the flywheel to clear the hub in the clutch disc. It took about 10 minutes on a 16" lathe. here's the website for wilcap: http://www.wilcap.com/
The owner, Pat I think is his name, is really helpful. If you need more info I can take a picture or 2 of the job I did and post it here. It was alot of work but I know it sure made that old cabover a joy to drive. Hope this helps.
BE different....ACT normal.
Old 11-12-2005, 12:42 PM
T5 to Flattie
I'm running a T5 in my 46 Ford PU behind the 8BA. I got the adaptor kit from Cornhusker Rods in NE. I've got the number for them someplace. Works like a champ. Had to do justa touch of grinding on the inside of the adaptor cause the starter ring was touching in one place.
