Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flat head Valve spring remover Tool???
Old 08-20-2009, 07:19 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
These are the tools that look like a big "C" clamp. the flat round end goes against the top of the valve and the split end goes over the valve spring in the block. Then the screw portion is tightened by hand or over-center lever. This pulls the retainer towards the valve head. Then you can get to the keeper (valve lock). When installing, grease the valve lock so it will stick to the valve.
