Flat spot when accelerating - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 11:42 AM
I have chevy 383 stroker with 650 Vacuum carb. When accelerating there is flat spot/hesitation before acceleration takes place, very irritating. I fitted the carb out of the box without any adjustments.
Old 02-18-2009, 12:01 PM
Check for vacuum leaks around the intake manifold & carburetor gasket. My dad's car did this & when I pulled the intake the gasket came apart in several pieces. Also, check all vacuum lines as a hole or one disconnected can cause this too.
Old 02-18-2009, 12:49 PM
Last journal entry: frame build
Check your float level
Check to make sure your getting a full stroke on the accel pump
Most vac secondary carbs can be adjusted to slow the secondary opening. Do this a little at a time till the stumble goes away.
Old 02-18-2009, 04:19 PM
ericnova72's Avatar
More for Less Racer
Sounds to me like you need a larger pump shot, i.e. squirter nozzle and possible an accelerator pump cam change. Very common on modified engines. I have yet to put a racy motor together that worked with an out-of-the-box carb calibration, they ALL need tuning.
Old 02-18-2009, 04:44 PM
Time for timing!
I agree with all said so far!
But also check your timing and note where it is. Advance it about 3-5 degrees at idle and see if that helps ....as long as the hesitation happens at lower RPMs.
Steve
part throttle flat spot ss427 Engine 1 05-11-2005 12:31 PM
flat head question mercmama Engine 7 03-29-2005 06:59 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Flat Black Paint sully Body - Exterior 11 01-14-2004 04:19 AM
