Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - flat tappet to roller cam
Old 05-22-2004, 05:45 PM
toddtheodd's Avatar
toddtheodd toddtheodd is offline
2000-6400 power range
298286 lift
227234 lift at .050
.478".480" duration at valve
.319".320" duration at lobe
112 Sep 108 Int C/L
or
2200-6800 power range
300310 life
242252 lift at .050
.525".540" duration at valve
.350".360" duration at lobe
110 Sep 106 Int C/L
are either of these better?
I was wanting to keep the power band in the 1000 to 6000 rpm range, these are more of the 2000 to 6500 range.
my 350 is in a 72 c-10
As I stated in the beginning, I'm only wanting power in the 1000-6000rpm range. I don't plan on spinning it past 6k.
Yes it is the stock bottom half.
