Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flat tappet to roller cam
Old 09-21-2006, 10:22 AM
FEDDO's Avatar
FEDDO FEDDO is offline
What techntool said. the 302 dosen't have the torque a larger eng has. To get a smaller eng to do the job you need a longer stick under the rock,GEAR, in case you don't under stand. the aod should not be in o/d when you are pulling.
