Flat tappet to roller cam conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2012, 12:52 PM
T-bucket23's Avatar
Wiki Edits: 26
I currently have a flat tappet cam in my 350 in the T-Bucket but I am quite sure my block is setup for a roller cam. Besides the cam and lifters what else would I need for parts to make it a roller or would I be better off using one of the retro kits. I believe there is a retainer for the factory roller lifters that I would need.
Thanks
Chet
Old 05-09-2012, 12:54 PM
How fast is fast enough?
Retainers and "spider" that holds the retainers in place. Depending on the cam you can reuse factory lifters. If you go aftermarket lifters get the travel limiting ones.
Old 05-09-2012, 01:15 PM
engineczar's Avatar
Hey Chet,
The pushrods will be shorter. For the factory OEM setup the timing set will be different and you'll need the original retainer plate that goes between the timing gear and block.
BSE Racing Engines
flat tappet to roller cam HP difference sooper Engine 12 04-20-2010 12:04 PM
Flat tappet vs. Roller cam turchiac Engine 8 02-18-2010 12:33 PM
flat tappet to roller cam toddtheodd Engine 29 02-06-2007 06:06 PM
Flat tappet to roller cam johnc486 Engine 5 09-21-2006 04:50 PM
Flat tappet VS. Roller cam 67 Deuce 4 Me Engine 15 11-13-2005 03:24 PM
