Flat tappet vs. Roller cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2010, 09:25 PM
I thought that one the benefits of a roller cam was the ability to have higher lift numbers with less duration @50 which would provide good low speed torque and throttle response with good top end power as well. I'm looking at these two cams with pretty much the same advertised duration and close duration @50, however the flat tappet cam has more lift than the roller cam, would this cam make more power because of this increased lift? I know that i can call the cam company's but the more input the better thanks
XE274H 230/236 @50 with 552/555 lift 110 lsa
XR276HR 224/230 @50 with 510/510 lift 110 lsa
Engine is a 9:1 454 don't know exact compression, flat tops with 101cc heads.
Old 02-18-2010, 01:40 AM
SSedan64's Avatar
Three-Way Cam Lobe Shootout
http://www.carcraft.com/techarticles...test_time.html
Old 02-18-2010, 07:52 AM
Thank you for your reply SS sedan, very good article. The roller cam in this test has more lift than the flat tappet. This is why im confused by the two cams above, the roller has similar duration but less lift. It seems that comp cams hydraulic rollers don't have more lift than they're comparable flat tappet designs. Confusing?
Old 02-18-2010, 07:58 AM
SSedan64's Avatar
The way the Roller cam lobe is shaped allows much more duration from mid to max lift than the Flat tappet. So, you can get more air flow with less lift with a Roller.
Old 02-18-2010, 10:50 AM
Ahh ok. Never knew that thanks.
Old 02-18-2010, 10:53 AM
How fast is fast enough?
two different cam lobe designs. there are flattappet cams with more lift androller cms with less lift.
Old 02-18-2010, 11:03 AM
So given the same engine combo the roller would make similar power of the flat tappet with less lift?
Old 02-18-2010, 12:29 PM
Simmilar yes, but not as much.
Old 02-18-2010, 12:33 PM
ok cool thanks
Flat cam in F4 Roller Block Carlos9 Engine 3 11-17-2009 09:45 PM
roller or flat tappet chrismac Engine 10 07-08-2009 08:47 PM
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
Flat tappet VS. Roller cam 67 Deuce 4 Me Engine 15 11-13-2005 03:24 PM
