flat topped pistons or stock - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2002, 07:17 AM
Post flat topped pistons or stock
are flat topped pistions better tan stock pistons? If so then why? what do they do?
Old 10-16-2002, 04:23 PM
mustang66maniac's Avatar
Ford Freak
Post
I was under the impression that most stock pistons are flat top.
Old 10-16-2002, 04:43 PM
SJFast's Avatar
Post
Flat tops will give higher compression ratio than the dished top ones will.
Old 10-16-2002, 07:17 PM
dmorris1200's Avatar
doesn't play well with others
Post
Hey Jeff it's called 'engine section'.
BUILT FORD TOUGH
