Flatbed trailer - what length? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2004, 06:48 PM
dh79's Avatar
I'm thinking about buying a flatdeck trailer for hauling cars around. What would you say is a good length for the trailer deck? 16' trailers seem to be a bit cheaper, but maybe I need an 18'? What are you guys using? I want to be able to haul pretty big cars. It has to be able to hold my 64 oldsmobile jetstar 88. This isn't a small car. Would it fit on a 16' deck?
Thanks,
dh
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 10-08-2004, 07:43 PM
302 Z28's Avatar
Most car hauler flat bed trailers that have the rear section that is angled down a bit (dovetail) are 22 feet long (tongue and all). You might consider a dovetail trailer if you have a car that is low. The dovetail decreases the angle of the ramps allowing the car to clear the back of the trailer as it rolls onto the ramps..
Vince
Old 10-08-2004, 08:19 PM
19_Chevelle_69's Avatar
Just making my rounds...
Last journal entry: Propane stuff - 2
We have a 16' with the dovetail, or beavertail ramp ends, and the open center for less trailer weight.
It works very well with the SBC Mustang race car, and handled the '79 Lincoln I just scrapped OK.
But, if I were to buy another one, I would go with the 18' to have more room for a bigger (deeper) toolbox instead of the shallow one that we have now.
Don
GM Tech Guild - Grand Master Technician
1969 Chevelle 355/TH350/3.08
2001 HD Sportster 1200
Old 10-08-2004, 10:33 PM
Re: Flatbed trailer - what length?
I have a 16 footer.........and it works for me BUT you should go ahead and get the 18 footer.......at least.
The 1964 Olds is a big car. With the 18 footer ( or even a 20 ) you can move the car forward/backward to get the tonque weight right.
I have the larger 2 and 5/8 ball also.........
All I haul are the 40 Ford or my 32 Ford.............see my avatar.
Old 10-10-2004, 03:30 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
18' with a 2' dovetail.
Old 10-10-2004, 06:52 PM
adtkart@aol.com
Deuce... That trailer looks long enough. You didn't need to shorten the car. OUCH
Old 10-10-2004, 07:39 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Trailer lenght
It took a little bit to upload the picture to my gallery, but you can see my truck and 14 foot flat bed trailer in there. I don't have a dove tail, just two 6 foot ramps to toss in the truck in the box after loading. It seems to work well enough for me, but if I were to buy another trailer, I'd get at least an 18' with a dove tail.
Old 10-10-2004, 08:24 PM
dh79's Avatar
Great, thanks for the replies. I'm going to keep my eyes open for a good 18'. I'd definately like a dovetail, but it's going to kinda depend on what I can fit in my budget.
Since we're on the subject of trailers, anybody have a preference between electric or hydraulic surge brakes?
Old 10-10-2004, 09:27 PM
schnitz's Avatar
Wiki Edits: 54
I can't say for sure on either. The trailer has electric brakes, but I still haven't bought the setup for the truck. It costs around $125 installed so maybe I should get it.... Soon.
Old 10-10-2004, 09:48 PM
Old enough to know better
Pick your posion on brakes.
Electric give you much better control but require a controller in any vehicle you use to tow.
With surge (hydraulic) brakes, you don't have the ability to control them but you can drop the trailer on anything that has a tow ball and you still have brakes. For a big trailer - like an RV - electric is the clear winner. For smaller trailers, it's much more of a toss up. If you tow on snow and ice, go with the electric. If you do general towing and want convience, go with surge. I have surge on the boat trailer and electric on the flatbed. I give electric a slight edge but wouldn't consider changing a trailer from one to the other.
As far as size, I've carried a '90 Deville and a '56 Studebaker 4 door on my 16' but it is totally flat with longer ramps. I wouldn't want a 16' if part of it was the dovetail.
Old 10-11-2004, 12:14 AM
Last journal entry: Some pics
Since I am into the bigger cars such as my 74 coupe deville, I am looking at getting an 18 or 20.
Old 10-11-2004, 03:21 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I had a quite a long one when I towed mine across the country. 20 or 22' I believe. Used a 2" ball.
K
Old 10-11-2004, 07:37 PM
Pick one that suits your intended usage but do remember that the longer they are, the harder they are to manuver in tight places (unless you have a GMC Qudrasteer)
If you have a choice, the 2 5/16" ball is better simply because it gives you a greater safety margin. With a large car loaded, you could be up around the rated capacity for some 2" balls. My trailer may be a bit heaver than average but it tips the scales right at 2000 pounds.
Old 10-12-2004, 11:03 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
16' flatbed, 2 5/16 ball, electric brakes, no dovetail because I have a steep driveway the back edge barely clears as it sits now. The advantage to electric brakes is no one else usually has a controller so you tell them they cant borrow your trailer because its illegal to tow a tandem axle trailer without brakes. It saves on abuse from inexperienced driver tearing up your equipment . Largest vehicle I towed on it was a 72 Chevy 1/2ton long bed truck. I decided to add side rails for strength before I do that again. I have to say I would be more comfortable with an 18'.
Old 10-13-2004, 01:25 AM
2-manytoyz,
I know the feeling. The license plate on my trailer is mounted on a hinge because it was getting bent up every time I pulled in the driveway. Now it just swings back out of the way.
