Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Flathead 6 smoking and blowby
Old 01-20-2013, 06:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 67Elcamino View Post
Thanks guys I drained the oil today, added some cheap 40w oil, drove it around the block a few times and the white smoke seemed to go away a bit. Is there a chance that once I flush the oil again and refill with some good quality oil and maybe an additive the smoke will slightly go away? Once again compression was really good and even according to flathead 6 specs.
I will try different things and see if it gets worse. It runs great. Newest thing I found out about this car is that It has a 3 speed tranny with an overdrive and according to the manual you cannot use SEA80 Gear oil because it has black oils and contaminants that can damage the overdrive. It calls for a SEA50 Cold tested engine oil.. or SEA50 aviation oil.
Would the SEA80 gear oils have the contaminants described in the 1940 shop manual?
If the engine's running well, and seems to be getting better, I see no reason to not continue driving it.
Today's lubricants are a far cry from the crude (npi) lubes used in '40.
Eaton and CAT both use a 50w gear lube, but unless you learn something to the contrary I'd use a straight 50w motor oil.
You might want to ask over at P15 D24 forum, they cater to the old MOPARs.
