Flathead to C4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2007, 09:14 PM
Flathead to C4
I have a 49 Shoebox and am considering converting from the three on a tree to a C4 using a Flat-o-Matic kit. I know that Flatattack and Speedway both make kits too. I have heard the Speedway is problematic because of the fit. From the posts I have read, the Flat-o-Matic seems the easiest way to go.
I was curious if anyone that did this conversion had any regrets.
What C4 tranny would you recommend? I am looking for an aftermarket rather than a junkyard piece.
Also, for those of you who did this conversion did you replace the steering column? I would rather have a automatic column shifter than cutting up the floorboard.
Thanks.
earle
Old 09-25-2007, 09:29 PM
Crosley's Avatar
Wiki Edits: 1659
1970 to 1977 C-4 would be a better choice...
the fellows I;ve dealt with liked the Flat O matic setup.
Old 09-25-2007, 09:32 PM
Crosley's Avatar
Wiki Edits: 1659
photo of a C-4 with flat O matic adapter on the trans case.
Chrome Lokar shifter mount...
Old 09-26-2007, 10:22 PM
Thanks Crosley.
Flathead V8 ?'s " for school project" 51FordDuff General Rodding Tech 4 06-12-2009 02:55 PM
Flathead or 351 for my 30 sedan MustBnuts Engine 22 10-10-2006 08:55 AM
Replacing C4 with AOD Mustang50Clay Transmission - Rearend 5 05-04-2004 05:24 PM
Input shaft conversion for C4 k2mooch Transmission - Rearend 8 12-29-2003 10:36 AM
flathead and a C4 dmorris1200 Transmission - Rearend 5 09-01-2002 05:46 PM
