flathead help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2002, 06:43 AM
Post flathead help needed
I have a built 40 Merc w/ edelebrock heads. The motor has been in a garage for 35 yrs. I removed all the nuts off the studs but the heads won't come off. Any suggestions?
Old 11-06-2002, 08:44 AM
New Member
Talking
The first car I ever owned was a 1950 Ford 2 Door with a V8 Flathead. I remember having the same problem, I used some Marvel Mystery Oil. It come with a sirenge to help it apply to tight areas. I put it around the heads and in every nook and cranny the head had and then let it sit for a day or two and they came off pretty easy after that. How this might help.
