Flathead rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 06:48 PM
Flathead rebuild
can a novice do it? I have just finished a body off restoration of a 29 A including the engine (runs great) and it is time to move on. I'm working on a 53 ford flat head. I was rebuilt some time ago. rebuild tag reads bore-.060/rods .060/ mains .010. I plan to boil out the block/mag flux it and if the block is solid I'll move on to the crank--it appears that the insert (rod) spun on the crank (no. one journal) which scored the crank. Big question: will this engine rebuild or had it been pushed too far at the first build?
Thanks, Fitter
Old 01-26-2012, 09:17 PM
BOBCRMAN@aol.com's Avatar
Depends on how deep your pockets are.. The crank will probably be junk. It's already about max undersize. You could have it welded up and reground. But, it would be less expensive for an aftermkt or good used crank. Rods will have to be re-sized.
Flathead stuff ain't cheap.. Many shops don't know how to work on them. I constantly get screwed up flatheads from owners that had them at other shops
4L60e, to rebuild or not rebuild, that is the question ? old yukon Transmission - Rearend 31 04-07-2011 12:25 PM
49 flathead jogunne Engine 5 10-13-2006 04:02 PM
flathead v8 toolbox Introduce Yourself 1 07-27-2005 06:31 AM
To rebuild or not to rebuild - Engine (and Tranny) KristensRanchero Engine 13 09-07-2004 01:20 AM
flathead water pump rebuild Lazy Hog Farmer Engine 2 12-20-2002 06:45 PM
