Flathead trans ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2011, 05:56 PM
Flathead trans ?
Hello all, does anyone know if a '49 Ford flathead "4-speed" will bolt to a 59AB in my '46 w/the integrated bellhousing? Found one cheap, I know there is probably a granny 1st gear but i want to ditch the tourque tube crap. Or does someone know of an adaptor kit or something to hang a t5 behind it?
Thanks much,
Scott
Old 09-18-2011, 06:27 PM
Wiki Edits: 27
flat head info
There are probably more flathead experts on the hamb site, My brother built quite a few flatheads back in the day. I think what he used to do was look for the merc bellhousing If i remember right there was a factory short belhousing to go from the engine that had the longer bell as part of the block to the trans with no bell as part of the trans case . There are more aftermarket. flathead parts available today than 50 years ago. I had a friend that used an S 10 5 speed behind his scott blower equipped 36. flathead.
flathead v8 to t-19 trans texas webb Engine 4 03-25-2010 10:08 AM
trans for a flathead ford mikej6 Engine 1 02-03-2009 08:22 AM
Flathead Trans Problems roster haller Transmission - Rearend 1 12-09-2007 07:00 PM
Ford Flathead 8ba to a 34 Ford Trans. Nailheadforty Transmission - Rearend 2 05-13-2007 07:31 PM
SROD trans behind a Flathead 8BA Hotrod Hirning Transmission - Rearend 2 10-20-2004 04:21 PM
