flathead v8 oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2013, 06:00 PM
delawarebill's Avatar
just got this '51p/u yesterday.. i would like to know if the oil pressure gage (dash) is working correctly.. so my question is where do u tap in or plumb in tubing for a mechanical gage.
i also think i'm needing to pull the carb apart.. starving for fuel. been sitting for 4 yrs during it restore job.. idles good. and while i'm at it.. that oil canister ?? how do u drain it for oil changes.. and how much oil does it take ??? more dumb ????? to follow.
bill
Old 04-14-2013, 10:02 PM
bill
Bill the oil pressure fitting is on the passenger side on the back of the block. Unscrew the electric sensor and install the line to your mechanical gauge. Flattheads are known for low pressure at idl after theynget some miles on them. 5-10 pounds at idle with the engine hot is not unusual.
I have a pretty well built 51 Merc engine with a freshly turned crankshaft and it will idle hot at about 22 lbs. Going down the road it will run around 50 lbs.
The Following User Says Thank You to John long For This Useful Post:
delawarebill (04-15-2013)
Oil for a Flathead rsfyj General Rodding Tech 8 03-12-2013 12:30 AM
8ba Flathead oil pressure question belvydeuce Hotrodding Basics 3 08-05-2009 09:41 AM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
Please help to diagnose- engine with no oil pressure. Oil pump failed? killerformula Engine 4 12-26-2006 10:25 PM
Crankcase pressure effect on oil pressure? cboy Engine 8 06-12-2005 08:04 AM
