Flathead V8 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2006, 07:43 PM
Alright, see if there are any flathead gurus, i'm working on a 51 mercury and it has the v8 flathead, i rebuilt the carb and we started it up(started right up.....points for me building the carb)
and immediatly started this awful knock like it going to throw a rod out the side(owner said it didn't do it before)
So i do a compression check , all cylinders at 135-142psi except for the front #1, it has 0, doesn't even push on the thumb or anything
So now i'm trying to figure out what next, i was looking in the cylinder and it looks like the intake valve isn't opening(its not moving at all maybe stuck open? doesn't really explain the knocking tho)
I put some oil in there to see if it would seal the rings up, but still zero compression
I don't think its a head gasket because the cylinder next to it is fine, and there is no water in oil or water in cylinder or oil in coolant.
I'm thinking a valve train issue or rings? leaning towards valves
any word from the experts?
Thanks
Brendan
Old 09-06-2006, 10:40 PM
BOBCRMAN@aol.com's Avatar
It's funny how the owners didn't hear that terrible knock before! Why was it brought to you? If the noise is that loud it surely isn't a valve. At most you would get a noisy "Tick". No compression and loud noise, usually adds up to a piston/rod type problem. Anyhow, you are going to have to pull the head.. Good luck
Ford Flathead Six Speed Equipment DJD Engine 3 12-14-2009 07:16 PM
Flathead v8.....any good? '54-Hunter Engine 13 01-22-2009 02:25 PM
flathead V8 for a 1950 Lincoln Cosmo helenwheels Engine 20 08-20-2008 03:23 PM
Ford flathead carb and intake confusion rcgerchow Engine 6 09-18-2003 12:24 AM
Most common problems with Flathead V-8's? '54-Hunter Engine 2 02-15-2003 04:39 AM
