Flattening agents.. need help
2K views 7 replies 4 participants last post by  rrmccabe
I have some omni flattening agent laying around that i would like to use up and at the same time i would like to make the wheels for my project satin.. i use spi universal clear.. is there some way i can test and see if this will work? im new to mixing different products around and i would rather not sand these wheels twice.. thanks
#2 ·
Any Flattening agent will work in any clear or paint. (Shake well, first)
95% of the flattening products out there is made with OK412 and only difference will be is how strong they have the mixture.
So one brand may take 20% to another brand that may take 30% to get the same flatness.
Also the higher solids the clear the more flattener it will take.
#6 ·
Keep shaking the gun as you paint too. I have found out that if you sit the gun down for a few minutes the flattener will settle out.
Flattener is twitchy and doesnt take much in the bottom of the cup to throw your flatteness off.
Just look at a flattener tech sheet and see how much difference 1oz of flattener per quart swings the %.
Rich
