Flattening agents.. need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2005, 11:25 PM
Last journal entry: metal finish
I have some omni flattening agent laying around that i would like to use up and at the same time i would like to make the wheels for my project satin.. i use spi universal clear.. is there some way i can test and see if this will work? im new to mixing different products around and i would rather not sand these wheels twice.. thanks
Old 08-19-2005, 05:19 AM
BarryK's Avatar
Any Flattening agent will work in any clear or paint. (Shake well, first)
95% of the flattening products out there is made with OK412 and only difference will be is how strong they have the mixture.
So one brand may take 20% to another brand that may take 30% to get the same flatness.
Also the higher solids the clear the more flattener it will take.
Old 08-19-2005, 06:38 AM
I've mixed flattener brands in the past and never had a problem. Like Barry said, some are definately weaker than others.
Old 08-19-2005, 01:07 PM
Does more of the clears activator needed or just mix the clear as usual and add this in?
Old 08-19-2005, 01:36 PM
BarryK's Avatar
Always activate at proper ratio first than add the flattener.
Old 08-19-2005, 02:43 PM
rrmccabe's Avatar
GM Muscle
Keep shaking the gun as you paint too. I have found out that if you sit the gun down for a few minutes the flattener will settle out.
Flattener is twitchy and doesnt take much in the bottom of the cup to throw your flatteness off.
Just look at a flattener tech sheet and see how much difference 1oz of flattener per quart swings the %.
Rich
Old 08-19-2005, 03:32 PM
I dont use ppg's products anymore.. im looking for tech sheets online but cant seem to find them.. anyone have a link to the tech manual?
Old 08-19-2005, 05:32 PM
rrmccabe's Avatar
GM Muscle
How about here.
http://www.ppg.com/cr-refinish/phase...roductInfo.asp
Rich
