Flearing Sheet Metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2007, 12:32 AM
Does anybody know ehre to get a flearing tool to flear flat sheet steel? Perferably a few inch in diameter Trying to do some plates for boxing. Thanks
Old 09-01-2007, 01:33 AM
Metal Twister's Avatar
Change is Opportunity!
Last journal entry: ( Chop Um-Up ) 1947 Plymouth Sedan Chop
When I think flaring, I think tube or pipe. What do you mean by flaring sheet steel? how thick are you talking about 1/8, 3/16?
Oh, do you mean a Flair tool to flair a hole in sheet metal? Jet busy with the lathe or you can buy them from these guys MITTLER BRO.
Old 09-01-2007, 08:07 AM
seriousracer's Avatar
be a man dodge tree bark!
got a lathe make your own ....
how we did it...
Old 09-01-2007, 08:55 AM
We made our own also.
Old 09-01-2007, 09:04 AM
boatbob2
flaring sheet metal
im not positive that i know what you are talking about. but take a piece of hard wood,(oak,maple) using a hole saw,cut a hole the size you want,in the wood,sand a bevel in 1 side of wood,take a socket about 1/8 in smaller than the flare you want,put everything in a hold down clamp,and start beating the flare. (you may have to heat the metal with a torch. hope this gets you going in the right direction. if you have a lathe,it would be easier too turn the flare.
Old 09-01-2007, 09:18 PM
Will I ever get it done?
Last journal entry: Passenger Door
http://www.irvansmith.com/catalog2/p...an_flare.shtml
http://www.fournierenterprises.com/equipment.htm
http://www.vansantent.com/sheet_meta...lare_tools.htm
Bare Knuckles Champ
Last journal entry: Made a wrench...
If you're talking about dimple dies, which is the closest thing I can think of from what you're saying, the best I've seen are from Trick Tools. I believe their website is vanzandt.com, but google Trick Tools & I'm sure you'll find it.
If this is what you want, there are a few threads with pics over on Pirate. I also have one of their catalogs & can give you more details if I'm on the right track.
Old 09-04-2007, 09:40 PM
Nice
Thanks for the ideas. Being that I dont have a lath im out of luck there and the dies are pretty spendy. I was looking through a tool catalog and found bearing race presses. Im going to try thoughs. I'll let you guys know how it works and looks when I get there. Should be starting in a month or so.
Old 09-05-2007, 05:45 AM
where do you live at?
Old 09-07-2007, 07:59 PM
Kent
I live in Kent, WA.
Need Sheet Metal Welding Help cab Body - Exterior 28 02-19-2007 04:25 AM
sheet metal work robs ss Body - Exterior 2 11-22-2006 04:19 AM
Where to buy Sheet metal cab Body - Exterior 12 07-25-2006 07:38 PM
Bending sheet metal eric302 Body - Exterior 7 02-18-2004 05:44 PM
sheet metal help?? gmthomas44 Hotrodders' Lounge 2 09-17-2002 09:53 AM
