-   -   fleet16 (http://www.hotrodders.com/forum/fleet16-227034.html)
fleet16 12-10-2012 04:05 PM
fleet16
I am trying to figure out what cam I have ? There are two # on the end of the cam one of which is C 275 the other is 950389 I would be very grateful for any help
cobalt327 12-11-2012 02:44 AM
The C275 is prolly a date code (March 27, year ending in 5). The other number is gonna be hard to pin down, it doesn't look like any of the common cam maker's part numbers, IMO.
You can measure the base circle and subtract that from the lobe and see what the lift is. Do both an exhaust and intake lobe, maybe you'll get lucky and cross that to a cam. But w/o the duration numbers, it's a long shot.
You can degree the cam to get the duration and timing specs if you have a degree wheel and dial indicator.
