Flex dipstick for a 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2002, 05:57 AM
New Member
Post Flex dipstick for a 350
This rookie has a dump question. I've installed a flex dipstick on the 350 trans, after installing the body, I now have a low point in the flex hose of the dipstick. That is to say that the hose dips below the level that the hose enters the trans. So when I pull out the dipstick, I read all the fluid that is trapped in the lower section of the hose and not a true level of the trans.
Is there a trick to it or do I need to reroute the hose so I do not have the dip in it?
Old 07-16-2002, 12:16 PM
Peg_Leg_Pete
Post
You "will" have to relocate the dipstick tube so there is no dip or else you won't be able to get a correct reading on the stick.
Hope this helps
