Flex Fan Direction - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2012, 07:24 AM
Flex Fan Direction
I'm a little confused with the way the flex fan works on a V8. Why does it blow engine heat towards your radiator instead of sucking cold air through your radiator. What happens when you drive and the natural flow of air onto the radiator flows towards your engine but the fan still blows air forward. Does not make sense does it.
Old 12-10-2012, 07:40 AM
Banned
it doesn't UNLESS you put a reverse rotation fam on a v belt front dress.
lots of engines when they went to one belt systems (serp) the water pump goes in reverse... even tho. you can bolt on the older pump and fans.. neither will cool all that well ,if at all
Old 12-10-2012, 07:42 AM
delawarebill's Avatar
Huh ????
what veh are u talking about first... but as far as i know the fan attached to the engine is a puller and u have a pusher in the wrong place... if u got a sbc then engine turns in a c/w direction looking at the front of engine crank, so the fan will also turn c/w. now still at the front of car with a fan blade at 12 o'clock the closest part of the fan is on the right, closest part to the front of car or rad.
Old 12-10-2012, 10:17 AM
sedanbob's Avatar
I have an sbc with a serpentine belt system - it uses a reverse rotation water pump. If the OP's fan pushes air then he has the wrong fan blade for his setup (regular or reversed).
Old 12-10-2012, 11:09 AM
Wiki Edits: 27
bolt holes
wrong fans sometimes work ok at slow speed then not let air flow at highway speeds. I even heard of one guy that rat tail filed the holes so the Wrong fan could bolt on. actually the reverse rotation water pumps were designed to pump water the intended direction
Old 12-10-2012, 02:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A correctly orientated engine-mounted fan pulls air through the radiator, as has been said. If yours is trying to push air towards the radiator you have to reverse the pitch of the fan blades.
Old 12-10-2012, 04:05 PM
life is a temporary assignment
If it's a fan that can't be reverse then you need to install it in front of the rad..Blowing in.. If it can be reversed, Then reverse it and install it behind the rad.. It work's much better on the inside sucking air from the front..
Old 12-10-2012, 11:38 PM
I totally agree with all of you. Thank you for the confirmation. It is a small block turning c/w if you look from the front. The blade however has a 'front' and 'back' stamped on it and if I would connect it as indicated it would blow forward instead of suck through the radiator. I see no problem in reversing the fan.
Old 12-11-2012, 12:19 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your fan was used on a serpentine set up and you have V-belts (or vice versa), so you're going to need a different fan altogether. Maybe that's what you meant...
The good thing is you caught it early before overheating the engine or getting stranded somewhere.
question about old heater fan direction yragat Electrical 16 10-04-2011 09:32 AM
fan shroud flex fan and water wetter for valiant elcaminodragster Engine 15 09-05-2009 09:52 PM
electric fan direction yragat Hotrodding Basics 44 02-23-2007 08:52 AM
Flex Fan ? 18-FEVR Engine 5 05-27-2005 09:24 AM
flex fan 75sprintguy Engine 42 03-05-2004 09:21 PM
