Flex hoses to master cyl? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2009, 05:16 PM
I've seen this done on a nice '37 Ford and wondered if anyone knows the fittings and lines needed and where they can be found. The lines from the master cylinder to the junction block for the front brakes and to the proportioning valve were stainless braided hoses instead of hard tubing.
It not only looks nice and neat, but it would buy me some extra room because the closest I can bend the line seems to be about 2" from the end, and the ports on my master cylinder point toward the engine.
Thanks!
Old 12-27-2009, 06:14 PM
Wiki Edits: 31
probably used braided stanless brake line. would normally go to the calipers where they would be flex.. I don't think it is DOT approved tho.
Old 12-27-2009, 07:13 PM
kleen56's Avatar
I guess it can be done, I never have gone that way. I always use hardline from the Master cylinder to each wheel. From there, I'll use stainless to connect to the wheels because of movement. Hardline is also easier to bleed than steelbraided line. Check some of the aftermarket brake suppliers for lines and parts, etc.
Old 12-27-2009, 08:10 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The problem with using hose instead of tubing over long distances is the hose expands under pressure using up pedal travel and you loose feel in the pedal. If you need to use hose for clearance, only go a short distance from the master cylinder to the frame and then use steel tubing on the rest of the frame, and back to hose to connect to the wheels. Earl's and other companies make pre-made stainless brake hoses of various lengths, or you can make your own.
Andy
Old 12-27-2009, 10:35 PM
Shortness
Yep, I'd only want to go a little way with the hose. My question is really related to the fittings, as the M/C seems to have pipe thread with adapters to the flare fittings on the brake tubing. How exactly to get from here to there. Thanks for the pointer, I'll check out Earl's.
Old 12-27-2009, 11:41 PM
aosborn's Avatar
Wiki Edits: 7
Can you post a photo of the master cylinder? I haven't seen one off a street car with pipe thread on the outlets.
Andy
Old 01-21-2010, 06:37 PM
I had to use banjo fittings on my MC because of clearance problems.
Another option is kevlar brake hose--Speedway motors has them in all kind of lengths ,they have AN ends
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
Stock Monza Master Cyl work with aftermarket disk brakes? Quarter Flash Suspension - Brakes - Steering 1 11-19-2006 05:31 PM
brake master cyl question! 67 Deuce 4 Me Suspension - Brakes - Steering 3 08-08-2006 12:47 AM
Relocating master cyl on a 34 302 Z28 Suspension - Brakes - Steering 8 11-16-2003 10:42 AM
