flex plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2010, 03:09 AM
flex plate
ok i gotta order a new flex plate for my 350 chevy so how do i tell which one i need external or internal balanced and or one or 2 piece rear main seal i know its 168 tooth
Old 06-25-2010, 09:12 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Does your current plate have a weight on it? if yes, you need a weight.
the internal - external flywheels have a different diameter bolt pattern at the crank shaft.. external weighted unit is smaller bolt pattern
mini starter shearing teath off my flex plate chevy1500z71 Engine 5 03-22-2009 09:15 AM
Flex Plate Holes Dont Match Torque Converter mightycarlo10 Transmission - Rearend 3 03-07-2008 06:37 PM
Bend a Flex Plate? 2000jack Engine 7 07-26-2006 04:36 PM
flex plate bolt torque mike bryan Engine 1 11-13-2004 11:03 PM
