Flex Plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2013, 10:55 AM
Flex Plate
I have an 85 350 crate engine. I need a flex plate that will fit the engine and accept a 700-R4 trans. The center hole needs to be 2 1/2". the engine will be going into a 41 Chevy 2 door Coupe. Someone suggested that an 88 1/2 ton woud be the place to start (at the parts stores). I tried the "FRA-159" from Autozone but the plate hole is to small, I need something with a center hole of 2 1/2".
Another question I have is how to determine if my engine is internally balanced or not?
Old 03-23-2013, 11:23 AM
BOBCRMAN@aol.com's Avatar
Two piece rear seal 350 SBC is internally balanced. One piece rear seal is externally balanced on flex plate/flywheel.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
byroncall (03-23-2013)
Old 03-23-2013, 12:30 PM
rick 427's Avatar
Last journal entry: The 32's
You also have to determine if it's a 153 or 168 tooth flexplate that you need.And when looking, the bolt pattern on a stock 700 converter is 10.75.
The Following User Says Thank You to rick 427 For This Useful Post:
Flex plate scraping against BOP plate? ggevaert Engine 3 05-28-2012 09:18 PM
flex plate wayneooo Transmission - Rearend 1 06-25-2010 10:12 PM
Flex Plate Help Earasim Transmission - Rearend 6 06-17-2007 09:29 PM
flex plate muscle car Engine 1 05-28-2006 05:29 PM
Flex Plate superhero Engine 5 03-28-2006 11:49 AM
