flex plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2006, 12:44 PM
flex plate
can any one help . changing s/b 350 for another 350 blown, can i still use existing flex plate with new torque convertor 3500 stall cheers
Old 05-28-2006, 04:29 PM
BOBCRMAN@aol.com's Avatar
You can use the existing f/plate as long as the engines are both of the same rear seal/crank design..two piece seal crank takes different f/plate than one piece seal crank..
Flex Plate superhero Engine 5 03-28-2006 10:49 AM
454 flex plate t/a clone Engine 1 05-18-2005 07:52 PM
flex plate bolt torque mike bryan Engine 1 11-13-2004 11:03 PM
What`s a good Flex Plate? KeithB123 Engine 1 09-23-2003 05:38 PM
