Which flex plate do I need for a SBC 307? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 11:17 PM
willys36@aol.com's Avatar
Wiki Edits: 21
OK, I know I have repeatedly said I would NEVER put a SBC in any car I built. Technically I am not now since I am building a '59 el Camino for/with my grandson and HE is putting in a 307.
I tried to buy a flex plate on ebaY and the guy says I need to tell him if I need a 153? or 168? tooth plate. That sounds ignorant to me that Government Motors would put different plate in virtually identical engines but so be it. Early hemis only need one part #.
How do I tell which I need? Is it a function of what starter is used?
Old 09-07-2009, 11:53 PM
ericnova72's Avatar
More for Less Racer
It is a function of what starter is used. If the starter bolt pattern is straight acrossed the nose, it uses the smaller flexplate/flywheel. If the starter pattern is diagonal acrossed the nose, it uses the bigger flexplate/flywheel.
Old 09-08-2009, 07:47 AM
Wiki Edits: 21
Thanx! And can I assume either starter will fit any SBC? Is there a performance advantage to either starter design? We are running a 2004R tranny, is one flex plate better for that?
Old 09-08-2009, 09:14 AM
the smaller 153 flex plate is nice if the engine/trans compartment is a tight fit. Old V8 nova's used them for this reason. 70's and early 80's tend to be 168, then gm went back to the 158 in the late 80's and 90's.
also be aware that there are two different torque converter mounting hole patterns used.
furthermore, later model 153 tooth fit don't fit the old cranks very well as later model 153 tooth doesn't have enough room for the offset weight on the two piece seal crank. It bents the later model flex plate when you bolt it to the older cranks
old el camino's are on the small side. so I would use a 153 tooth for 1966 v8 nova with a starter to match (straight across both pattern). Get the flexplate that has both torque converter patterns to make sure it fits the converter. A TCI flexplate from summit racing will be your best bet.
Old 09-08-2009, 09:18 AM
http://www.summitracing.com/parts/TCI-399573/
Old 09-08-2009, 09:37 AM
starter
Look at your block and make sure it is drilled for either starter. Some of these came with only two holes. Also found some with the third hole drilled but not tapped. They can be drilled and tapped, but it is a lot easier when engine is upside down on engine stand.
Old 09-08-2009, 11:17 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Hey----I got one of those for a 153 tooth
Was on my 66 PG which has since been replaced with a trans that needs a clutch pedal
(Actually----I think it is new-----bought it and then put in the TKO
Old 09-08-2009, 12:10 PM
SSedan64's Avatar
Starter mounting holes. >> http://www.chevytech.com/2c42o6.html
Old 09-08-2009, 02:31 PM
Wiki Edits: 21
Well, send 'er on over!! It's amazing but I think I am out of things to beg you for!!
Old 09-08-2009, 02:34 PM
Wiki Edits: 21
Thanx, I'll look at the block tonight. I don't recall ever running into the diagonal pattern in my many days of servicing the many Chevys I've owned over the years. Are the smaller plates more common?
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
New 327 flex plate for th350 pretorin Engine 1 11-30-2003 08:25 PM
What`s a good Flex Plate? KeithB123 Engine 1 09-23-2003 05:38 PM
t350 to 327 flex plate problems Armond Transmission - Rearend 1 09-16-2003 12:55 AM
Flex plate switch ?? Ed ke6bnl Engine 3 08-08-2003 06:50 AM
