Flex Plate or Fly Wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2007, 03:23 PM
I am taking out my Muncie and replacing it with a TH350 Auto on my 327 SBC.
Do I replace the Fly Wheel with just the flex plate? I here and read about people using the word fly wheel in conjunction with an automatic. Are the just referring to the flex pate when they say this. I was under the understanding that you just replaced the fly wheel with the correct flex plate, is this true.
Thanks
Old 10-20-2007, 03:30 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Manuals get a flywheel, autos get a flexplate. You're right, you remove the flywheel and put a flexplate in its place. Then the torque converter bolts to the flexplate.
Old 10-20-2007, 03:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
Decades ago the flexplate / flywheel that transfered power from the engine to the new fangled automatic trans was a flex plate with a spring loaded center like a manual trans clutch disk.... so the name flexplate stuck on the automatics.
Not all the early automatics used a spring loaded flexplate.
long way to say that depending on where / what / who you talk to , they may use the term flexplate or flywheel on an automatic trans.
Old 10-21-2007, 03:11 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Anybody ever pulled an auto trans out of a 60s GMC with the giant V-6? They use a heavy cast iron flywheel with teeth, PLUS a wierd flex plate!
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
bolts size for fly wheel on ford 302 gun70runner Engine 5 05-26-2006 07:13 PM
HELP with numbers on sb fly wheel please!!! Robbie Engine 0 05-29-2004 05:28 PM
FLEX PLATE , FLYWHEEL what are the differences? terror385 Hotrodding Basics 2 01-12-2004 02:42 PM
Cracked Flex Plate mikewheel Transmission - Rearend 4 01-04-2004 06:54 AM
