flex plate question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2008, 02:59 AM
at present I have a 14"/168 flex plate on my 307 sbc motor about 1972 motor. the 283 starter has straight accross patern and does not fit the flexplate. can I just put a differant started to get this motor started, I only noticed a straight accross pattern on the motor. Will all the 350 motor and 307 have a bolt pattern for both starters, if not is there a started for straight accross pattern and for the 168 tooth flex plate, or will I have to change out the flexplate to a 153 tooth pattern to work thanks Ed
Old 09-19-2008, 03:19 AM
one_am's Avatar
holley guru
im pretty sure all small block chevys have dual patterns (it will take a strait or a stagered pattern starter). i would deffinatly buy a starter for the flexplate that you have instead of dropping the tranny and going through all that crap. take a look at summit's web site.
Old 09-19-2008, 05:50 AM
thanks for the fast reply. This motor does not have the trans on it it is just sitting in an old el camino and want to test the motor b4 putting it in my 72 el camino daily driver. I will get a staggard starter for it. love this site for the helpful people. Did do a search but the question of both patterns on a sbc I did not see thanks Ed
Old 09-19-2008, 05:51 AM
There are after market high torque starters available that have a dual bolt pattern allowing them to be used with the straight bolt pattern with either size flex plate.
Here's an example:
Name:	hi tq strtr.jpg
Bend a Flex Plate? 2000jack Engine 7 07-26-2006 05:36 PM
chevy flex plate v8 -6 the same ? whatwouldscoobydo Engine 1 07-26-2006 01:46 PM
flex plate muscle car Engine 1 05-28-2006 05:29 PM
671 rear cover plate question? binder47 Engine 16 12-21-2004 01:06 AM
flex plate bolt torque mike bryan Engine 1 11-14-2004 12:03 AM
