Flex plate scraping against BOP plate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2012, 06:14 PM
ggevaert's Avatar
Hello,
Been trying to hunt down a sound now for about a week and need some assistance. It sounds like a grinding/scraping noise that only happens under medium to heavy acceleration and only lasts for a few seconds; mostly when the truck is cold but recently i have been hearing it when hot but always when medium to heavy acceleration.
I thought it was the same problem I had initially (2 years ago), where the flywheel was scraping the metal flywheel/TQ shield (because of my BOP spacer) but since i spaced that shield out more it went away and have not heard it again until this similar sound last week.
I checked everything I could think of but I can't find any scrape marks anywhere that may point to the culprit; I am suspecting the flexwheel is hitting the BOP plate but can't prove it as I can't see in that space.
I am looking at the edge of the flywheel teeth (the part that would scrape first) on the side towards the engine and I'm not sure if it is worn; it isn't obvious and I'm thinking some of the shiny may be due to the starter engaging.
I included a picture of the BOP to flywheel spacing.
Any thoughts?
How much does a flywheel typically flex? And does it flex towards the engine or away?
Thanks
Cheers
Gary
Old 05-28-2012, 11:12 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are you running a shield ? it could also be the engine flexing to much and the fan making contact to the shroud or something. JMO
Cole
Old 05-28-2012, 11:29 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The torque converter flexes toward the motor/thrust bearing. Watch this video.
With the BOP adapter in place you don't have much room for flex.
Semper Fi
Old 05-28-2012, 08:18 PM
ggevaert's Avatar
BOP plate
eloc431962; I was running a shield that, in the past, had caused some scraping but that went away when I spaced it out more. I removed it last week after the sounds started again to eliminate it from the possible causes, I've been running without it for the past week.
68NovaSS; Thanks.
So likely culprit is the BOP plate, any thoughts on why it is getting worse now when it was fine since motor was put in (approx 2 years ago now)?
Anything getting worn out? Imbalance?
Thank You
flex plate wayneooo Transmission - Rearend 1 06-25-2010 09:12 PM
Need help installing a BOP adaptor plate.... ForceFed86 Transmission - Rearend 3 08-25-2009 01:18 PM
Flex Plate Help Earasim Transmission - Rearend 6 06-17-2007 08:29 PM
flex plate muscle car Engine 1 05-28-2006 04:29 PM
adapter plate for th350 chevy to BOP speedfrk3 Transmission - Rearend 2 12-12-2002 09:46 AM
